Displays the EAPS configuration (control, partner, or not added to an EAPS domain) of a specific VLAN.
| vlan_name | Specifies a VLAN name. |
N/A.
Use this command to see if the specified VLAN is associated with an EAPS domain.
The output of this command displays whether the VLAN is a control or partner VLAN for an EAPS domain. This command also displays if the VLAN is not a member of any EAPS domain.
If a VLAN is a partner VLAN for more than one EAPS domain, all of the EAPS domains that the VLAN is a partner of appears in the output.
The following sample output displays the EAPS configuration for the control VLAN orange in EAPS domain eaps1:
#show vlan orange eaps Vlan is Control in following EAPS domain: eaps1
The following sample output displays the EAPS configuration for the protected VLAN purple in EAPS domain eaps1:
#show vlan purple eaps Vlan is Protected in following EAPS domain(s):eaps1
The following sample output displays information about the VLAN default not participating in EAPS:
#show vlan default eaps Vlan has not been added to any EAPS domain
This command was first available in ExtremeXOS 11.0.
